Diamond Mesh Finish
Diamond Mesh Finish
Diamond Mesh Finish
Hello All
I have a drawing of a Quartz (Glass) component calling for a 220 Diamond Mesh finish.
Does any one know what is the equivalent is in either Micro inches or metric Um ?
 JimP
equifilant
RE: Diamond Mesh Finish
Nope, and I don't believe there really is one, since it would depend on the process used (grit blast?  lapping?  buffing with a cotton buff?).  Realistically, I think you could expect about an 8 u-in finish, plus or minus, using 220 mesh grit/polish.  A bit higher if used in a tumbler or vibratory deburr process.
The customer may be refering to the grit size in the grinding wheel used for fabrication.  I would expect a 220 grit (US mesh size) diamond wheel to produce a 32 microinch or better (probably no better than 20 microinch) finish on fused quartz.
Bruce
www.accuratus.com
Hi jimp187,
Further to my post on a fixed abrasive wheel, I have attached a curve showing surface roughness vs. abrasive size on BK7 glass.  This glass is a little softer than fused silica but results should be similar.
Source:
Zschlommer, W. Precision Optical Glassworking A Manual for Craftsmen and Designers.  SPIE vol. 472. trans. Sachdev and Maxwell. 1984.
Bruce
www.accuratus.com
The curve shown in my last post is for loose abrasive finishing eg lapping/polishing.
Bruce
www.accuratus.com
Why don't you simply ask the customer what it means. It sounds like they may have a standard setup for this finish.
At one time we were making a part with wrinkle paint surface. The customer actually supplied paint samples showing acceptable finish and unacceptable finish.
