Import parasolid error
I have a parasolid file from a supplier that will not import.
I get a couple differnt errors, depending how I attempt to open it:
"Invalid file contents" When I try to import it into an existing part
"An unrecognized interoperation request has been received" When I click on the icon (on my desktop) and open with NX.
The suffix on the file is "x_t"
I am on NX6
I do not know what CAD system the part was created in.
Does anybody have any suggestions on getting this parasolid to import?
I am on NX6
RE: Import parasolid error
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Also, VisMockup will open the x_t if you just want to look at it.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
That is a good point that you bring up. Typically If I need to send a prasolid file to someone - I usually pick an older parasolid version so that I am ssured that they can open it up.
