Importation of x,y,z points in to NX
Is it possible to read in a text file containing x,y,z coordinates of a part into the NX6? Thanks.
RE: Importation of x,y,z points in to NX
1. If you want to create a spline from the points, then there is a direct way to do this: Insert > Cureve from Curves > Spline, then pick "Through Points" and select your data file (it must be formatted correctly).
2. If you want your file to result in individual Point features, then this is not so pre-packaged for you, although there is a GRIP routine that can do this for you.
3. There are also other alternatives, but perhaps you can describe what it is you want to do with the coordinates after you import them to NX?
http://www.eng-tips.com/viewthread.cfm?qid=181530
http://www.eng-tips.com/viewthread.cfm?qid=150687
http://www.eng-tips.com/viewthread.cfm?qid=110602
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Did any of the above comments (ie: the links to all the old posts) help you?
thread561-200347: Creating NACA airfoil model
