Drafting - dimensions explode to mess when moving.
A colleague has a problem with a drafting view.
When he drags a dimension then all other dimensions in the view explode into a mess of lines that occupy a space several times bigger than the drawing view. It looks like they explode into being 5 times larger than the view(drawing scale 5:1) with odd tangent lines and bits of text showing.
Has anyone else experienced this problem?
RE: Drafting - dimensions explode to mess when moving.
Has your drawing more than one sheet? I have the problem with quite large drawing (both in size and in quantity of sheets) and sometimes in one sheet appeared dimensions from another sheet (see attached picture). I did not find any solution for this, only just reopening helped me.
I opened the drawing on my machine and it worked fine. We suspect something to do with memory size on that machine.
Or your graphics card.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
