How to reassociate parts with draft in ST1
Hi All
I am a new user to Solid Edge and I am struggling to re-associate the model with the draft after renaming files.
Can anyone help?
Paul
Can anyone help?
Paul
RE: How to reassociate parts with draft in ST1
Try a search of this site and you should find some other threads that have talked about it.
Revision Manager is very useful for moving, renaming and similar file management tasks.
Sadly, I don't think there is a built in tutorial for it which is a real shame as it really is quite a good tool - better than what's available on some other more common CAD products so I'm told.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks, I managed to sort it via the home button and 'manage source'. Thanks for the advice on revision manager. I will take a look at it.
Best regards,
Paul
Hope it helps.
Patrick
Cheers
Paul
Revision Manager is one tool you should really get to know.
It's the proper way to rename, copy, move and re-link files and is really powerfull.
However, with that power comes the ability to completely screw up a whole load of stuff, so start to learn on some test files and assemblies first.
If you need any help with it just come back here.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
This primer uses the menus and wizard (I prefer right click to access menu). It's old, but so is revision Manager. BUT it's a really useful tool, I use it daily.
It's a shame that the SE people never developed this further as it had great potential
