Automating the export of multiple parts as parasolid files
3
Is there a relatively easy way to automate the export of a group of parts as parasolid files?
We have a number (hundreds) of part family assemblies that we would like to automate the export into parasolid format.  It is nice and easy to have the family create the NX parts, but is there any way to do a batch export of all the NX assemblies into a parasolid format?  Is there a way to run a parasolid translation on a folder of NX parts?
We do not have any of the .net or cpp author/execute licenses so we'd have to do it with either a macro or journal.
Does anyone have any suggestions or examples that might work?
Jeff
RE: Automating the export of multiple parts as parasolid files
To what purpose is this being done?
Or to put it another way, what advantage are you trying to gain by doing this?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
There is a batch way to do a STEP export, but not a parasolid export:
To Get there in WINDOWS:
START > PROGRAMS > UGS UGNX_ > TRANSLATORS > STEP_ > EXPORT
John,
We provide models to our customers via our website.  The back end system utilizes a parasolid format to then convert to other file formats.
We have very "family" type products and we use part families to create the parts as well as configure the different assemblies.  It is easy enough to generate the NX part files from the families, now it would just be great if we could automate the process of converting those assembly files down to parasolid format.
We are trying to avoid a manual process of converting each file manually, which is a real killer when you are talking about thousands of part numbers.
STEP may work, but there are far more opportunities for geometry issues with STEP than parasolid.
I'm sure that this would be possible using an NX Open application, but if you were to develop that it would require that you purchase an 'author' license, but if part of your commercial endeavor is to "provide models to your customers" then I can't see how the price of that wouldn't be seen as a reasonable cost of doing business.
And if you don't wish to write the program yourself, there are several organizations/individuals which make their living doing programming like this whom you could contract this to.
John R. Baker, P.E.
Industry Sector
Cypress, CA
My main objective is to not have to purchase additional software, what will be used to write code that will have to be maintained each time we upgrade.
Coming from the I-deas side there was a lot of stuff that could be done with "program files", heck, some even wrote games that ran in Master Drafting!  No additional licenses were needed.
I hoped to find someone who might have done something similar.  I'm sure that people have had to do this and I don't think that it's something that should have to be coded in order to do a batch export of NX Parts in a directory into a parasolid format.
I know this could be done somewhat easily with the .NET or CPP author license, but then we'd also need the execute license as well, right?
I can't say that I'm fond of the way some of the "open" tools are licensed.  I know that Siemens is out to make money, but at some point all of the license requirements get to be frustrating.
Hi wundej,
You are in luck I have a journal that uses the ufs.Ps.ExportData() method to create a parasolid file from bodies. It is a bit rough as it was created to learn how to work with Windows forms and journals in batch mode, but you might find some use for it.
Regards Petter
CODE
' Parasolid batch exporter written for NX6
' V0.01 - 2010-03
' Petulf
' Uses windows forms to create a UI and the ufs.Ps.ExportData(tags, filename) function to create the parasolid file
' The ASM parsing text field is used to filter the part files ex)
' typing cylinder in the text field will convert all .prt files with cylinder in their name.
' Can be run from within NX as a journal or started from the command line
' c:\NX6\UGII\run_journal.exe psBatchExport.vb
Imports System
Imports System.Windows.Forms
Imports System.IO
Imports System.Collections.Generic
Imports System.Drawing
Imports System.Threading
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Public Class psBatchExport
    Public Shared thePsBatchExport As psBatchExport = Nothing
    Public Sub New()
    End Sub
    Public Shared Sub Main(ByVal args As String())
        ' Singleton
        thePsBatchExport = New psBatchExport
        ' Launch the windows form class
        Dim f As New BatchExportForm
        Application.Run(f)
    End Sub
End Class
#Region "Parasolid and File management"
Public Class ExportParasolid
    Dim theSession As Session = Session.GetSession
    Dim ufs As UFSession = UFSession.GetUFSession
    Public Function Export(ByVal file As String) As Boolean
        Dim loadStatus As PartLoadStatus = Nothing
        Dim currentPart As Part = Nothing
        Dim bodyTags As List(Of Tag) = Nothing
        Dim tags(-1) As NXOpen.Tag
        Dim exportFileName As String = Nothing
        Try
            currentPart = theSession.Parts.OpenDisplay(file, loadStatus)
        Catch ex As Exception
            If ex.Message = "File already exists" Then
                For Each partItem As Part In theSession.Parts
                    If partItem.FullPath = file Then
                        currentPart = partItem
                        Exit For
                    End If
                Next
            End If
        End Try
        Try
            bodyTags = GetBodyTags(currentPart)
            exportFileName = file.Remove(file.Length - 4, 4) + ".x_t"
            tags = bodyTags.ToArray()
        End Try
        Try
            If tags.Length > 0 Then
                If IO.File.Exists(exportFileName) Then
                    IO.File.Delete(exportFileName)
                End If
                ufs.Ps.ExportData(tags, exportFileName)
                currentPart.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.UseResponses, Nothing)
                Return True
            End If
        End Try
        Return False
    End Function
    Private Function GetBodyTags(ByRef thePart As Part) As List(Of Tag)
        Dim bodyTags As New List(Of Tag)
        For Each bodyItem As Body In thePart.Bodies
            bodyTags.Add(bodyItem.Tag)
        Next
        Return bodyTags
    End Function
End Class
Public Class FilesManager
    Private _directoryPath As String = ""
    Private _files As String()
    Public Property DirectoryPath() As String
        Get
            Return _directoryPath
        End Get
        Set(ByVal value As String)
            If IO.Directory.Exists(value) Then
                _directoryPath = value
            End If
        End Set
    End Property
    Private _filterString As String = "*.prt"
    Public Property FilterString() As String
        Get
            Return _filterString
        End Get
            If value <> "" Then
                _filterString = "*" + value + "*.prt"
            Else
                _filterString = "*.prt"
            End If
        End Set
    End Property
    Public ReadOnly Property Files() As String()
        Get
            If DirectoryPath <> "" Then
                _files = System.IO.Directory.GetFiles(DirectoryPath, FilterString)
                Return _files
            Else
                Return Nothing
            End If
        End Get
    End Property
End Class
#End Region
'' <summary>
'' </summary>
'' <remarks></remarks>
Public Class BatchExportForm
    Inherits System.Windows.Forms.Form
    'Dim theSession As Session = Session.GetSession
    'Dim ufs As UFSession = UFSession.GetUFSession
    Dim theFilesManager As New FilesManager
    Dim theExporter As New ExportParasolid
#Region "Threaded openFolderBrowser"
    ' This class is needed to ensure the folderbrowser is a STA thread
    Private Class OpenFolderBrowserHelper
        Private Shared _selectedFolder As String = ""
        Public Function OpenFolderBrowser() As String
            Dim newThread As New Thread(New ThreadStart(AddressOf ThreadedFolderBrowser))
            newThread.SetApartmentState(ApartmentState.STA)
            newThread.Start()
            newThread.Join()
            newThread.Abort()
            Return _selectedFolder
        End Function
        Private Sub ThreadedFolderBrowser()
            Dim folderBrowserDialog As New FolderBrowserDialog
            folderBrowserDialog.Description = "Select Part File Directory"
            folderBrowserDialog.ShowNewFolderButton = False
            folderBrowserDialog.RootFolder = Environment.SpecialFolder.MyComputer
            If folderBrowserDialog.ShowDialog() = Windows.Forms.DialogResult.OK Then
                _selectedFolder = folderBrowserDialog.SelectedPath
            End If
        End Sub
    End Class
#End Region
    Private Sub BrowseButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles BrowseButton.Click
        Dim browser As New OpenFolderBrowserHelper
        PathTextBox.Text = browser.OpenFolderBrowser()
        ValidateTextBoxPath()
    End Sub
    '' <summary>
    '' Main form loop, handles part conversion and updating of the exportlog textlist.
    '' </summary>
    '' <param name="sender"></param>
    '' <param name="e"></param>
    Private Sub ExportButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExportButton.Click
        theFilesManager.FilterString = FilterTextBox.Text
        If ValidateTextBoxPath() Then
            For Each file As String In theFilesManager.Files
                If theExporter.Export(file) Then
                    ExportLog.Items.Add("Succesfully exported " + file)
                Else
                    ExportLog.Items.Add("Failed to export " + file)
                End If
                LogDown()
            Next
            ExportLog.Items.Add("Export finished")
        End If
    End Sub
    Private Sub PathTextBox_Validating(ByVal sender As System.Object, ByVal e As System.ComponentModel.CancelEventArgs) Handles PathTextBox.Validating
    End Sub
    Private Sub PathTextBox_KeyDown(ByVal sender As System.Object, ByVal e As KeyEventArgs) Handles PathTextBox.KeyDown
        If e.KeyCode = Keys.Enter Then
        End If
    End Sub
    Private Function ValidateTextBoxPath() As Boolean
        theFilesManager.DirectoryPath = PathTextBox.Text
        If theFilesManager.DirectoryPath = "" Then
            ErrorProvider1.SetError(PathTextBox, "Path is not valid")
            Return False
        Else
            ErrorProvider1.SetError(PathTextBox, "")
            Return True
        End If
    End Function
    ' Method that scrolls down the listbox
    Private Sub LogDown()
        ExportLog.SelectedIndex = ExportLog.Items.Count - 1
        ExportLog.SelectedIndex = -1
    End Sub
    ' Enables copying from the listbox to the clipboard
    Private Sub ExportLog_Copy(ByVal sender As System.Object, ByVal e As KeyEventArgs) Handles ExportLog.KeyDown
        If e.Control And e.KeyCode = Keys.C Then
            Try
                Dim clipBoardString As String = ""
                For Each selectedItem As String In ExportLog.SelectedItems
                    clipBoardString += selectedItem + vbCrLf
                Next
                Clipboard.SetText(clipBoardString)
            End Try
        End If
    End Sub
    Public Sub New()
        ' This call is required by the Windows Form Designer.
        InitializeComponent()
    End Sub
#Region "Windows Form"
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()> _
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    <System.Diagnostics.DebuggerStepThrough()> _
    Private Sub InitializeComponent()
        Me.components = New System.ComponentModel.Container
        Me.ExportButton = New System.Windows.Forms.Button
        Me.BrowseButton = New System.Windows.Forms.Button
        Me.FilterTextBox = New System.Windows.Forms.TextBox
        Me.PathTextBox = New System.Windows.Forms.TextBox
        Me.Label1 = New System.Windows.Forms.Label
        Me.Label2 = New System.Windows.Forms.Label
        Me.ErrorProvider1 = New System.Windows.Forms.ErrorProvider(Me.components)
        Me.ExportLog = New System.Windows.Forms.ListBox
        CType(Me.ErrorProvider1, System.ComponentModel.ISupportInitialize).BeginInit()
        Me.SuspendLayout()
        'ExportButton
        Me.ExportButton.Location = New System.Drawing.Point(536, 274)
        Me.ExportButton.Name = "ExportButton"
        Me.ExportButton.Size = New System.Drawing.Size(76, 23)
        Me.ExportButton.TabIndex = 0
        Me.ExportButton.Text = "Export"
        Me.ExportButton.UseVisualStyleBackColor = True
        'BrowseButton
        Me.BrowseButton.Location = New System.Drawing.Point(536, 70)
        Me.BrowseButton.Name = "BrowseButton"
        Me.BrowseButton.Size = New System.Drawing.Size(75, 23)
        Me.BrowseButton.TabIndex = 1
        Me.BrowseButton.Text = "Browse"
        Me.BrowseButton.UseVisualStyleBackColor = True
        'FilterTextBox
        Me.FilterTextBox.Location = New System.Drawing.Point(12, 25)
        Me.FilterTextBox.Name = "FilterTextBox"
        Me.FilterTextBox.Size = New System.Drawing.Size(495, 20)
        Me.FilterTextBox.TabIndex = 2
        Me.FilterTextBox.Text = "ASM"
        'PathTextBox
        Me.PathTextBox.Location = New System.Drawing.Point(12, 72)
        Me.PathTextBox.Name = "PathTextBox"
        Me.PathTextBox.Size = New System.Drawing.Size(495, 20)
        Me.PathTextBox.TabIndex = 3
        Me.PathTextBox.Text = "c:\"
        'Label1
        Me.Label1.AutoSize = True
        Me.Label1.Font = New System.Drawing.Font("Microsoft Sans Serif", 8.25!, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, CType(0, Byte))
        Me.Label1.Location = New System.Drawing.Point(9, 9)
        Me.Label1.Name = "Label1"
        Me.Label1.Size = New System.Drawing.Size(139, 13)
        Me.Label1.TabIndex = 4
        Me.Label1.Text = "Assembly parsing string"
        'Label2
        Me.Label2.AutoSize = True
        Me.Label2.Font = New System.Drawing.Font("Microsoft Sans Serif", 8.25!, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, CType(0, Byte))
        Me.Label2.Location = New System.Drawing.Point(9, 56)
        Me.Label2.Name = "Label2"
        Me.Label2.Size = New System.Drawing.Size(58, 13)
        Me.Label2.TabIndex = 5
        Me.Label2.Text = "Directory"
        'ErrorProvider1
        Me.ErrorProvider1.ContainerControl = Me
        'ExportLog
        Me.ExportLog.FormattingEnabled = True
        Me.ExportLog.Location = New System.Drawing.Point(12, 98)
        Me.ExportLog.Name = "ExportLog"
        Me.ExportLog.ScrollAlwaysVisible = True
        Me.ExportLog.SelectionMode = System.Windows.Forms.SelectionMode.MultiExtended
        Me.ExportLog.Size = New System.Drawing.Size(495, 199)
        Me.ExportLog.TabIndex = 6
        'BatchExport
        Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.ClientSize = New System.Drawing.Size(623, 309)
        Me.Controls.Add(Me.ExportLog)
        Me.Controls.Add(Me.Label2)
        Me.Controls.Add(Me.Label1)
        Me.Controls.Add(Me.PathTextBox)
        Me.Controls.Add(Me.FilterTextBox)
        Me.Controls.Add(Me.BrowseButton)
        Me.Controls.Add(Me.ExportButton)
        Me.Name = "BatchExport"
        Me.Text = "NX - Batch Export Parasolid"
        CType(Me.ErrorProvider1, System.ComponentModel.ISupportInitialize).EndInit()
        Me.ResumeLayout(False)
        Me.PerformLayout()
    End Sub
    Friend WithEvents ExportButton As System.Windows.Forms.Button
    Friend WithEvents BrowseButton As System.Windows.Forms.Button
    Friend WithEvents FilterTextBox As System.Windows.Forms.TextBox
    Friend WithEvents PathTextBox As System.Windows.Forms.TextBox
    Friend WithEvents Label1 As System.Windows.Forms.Label
    Friend WithEvents Label2 As System.Windows.Forms.Label
    Friend WithEvents ErrorProvider1 As System.Windows.Forms.ErrorProvider
    Friend WithEvents ExportLog As System.Windows.Forms.ListBox
#End Region
End Class
3
Updated version that can actually handle assemblies.
CODE
' V0.02 - 2010-05
' Petulf
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
    Public Sub New()
    End Sub
        ' Singleton
        Application.Run(f)
    End Sub
End Class
        ' Open the part, if all ready open set as displaypart
        Try
                        theSession.Parts.SetDisplay(currentPart, False, False, loadStatus)
                        Exit For
                    End If
                Next
            End If
        End Try
        ' Fetch the sheet and solidbody tags from the part file.
        Try
            Dim tagsList As List(Of Tag) = GetBodyTagsInPart(currentPart)
            tagsList.AddRange(GetBodyTagsInAsm(currentPart.ComponentAssembly.RootComponent))
            tags = tagsList.ToArray()
            MsgBox(ex.Message)
        End Try
        ' Export the bodies
        Try
                End If
                Return True
            End If
        End Try
        Return False
    End Function
    ' Recursive function to retrive all components occurence body tags.
    Private Function GetBodyTagsInAsm(ByVal c As Component) As List(Of Tag)
        Dim componentTagList As New List(Of Tag)
        If c Is Nothing Then
            Return componentTagList
        End If
        Dim children As Component() = c.GetChildren()
        For Each child As Component In children
            If Not child.IsSuppressed Then
                For Each bodyItem As Body In CType(child.Prototype, Part).Bodies
                    Dim tmpNXObject As NXObject = child.FindOccurrence(bodyItem)
                    If Not tmpNXObject Is Nothing Then
                        componentTagList.Add(CType(tmpNXObject, Body).Tag)
                    End If
                Next
                componentTagList.AddRange(GetBodyTagsInAsm(child))
            End If
        Next
    End Function
    Private Function GetBodyTagsInPart(ByRef thePart As Part) As List(Of Tag)
        Next
        Return bodyTags
    End Function
End Class
        Get
        End Get
            End If
        End Set
    End Property
        Get
        End Get
            If value <> "" Then
            Else
            End If
        End Set
    End Property
        Get
                Return _files
            Else
                Return Nothing
            End If
        End Get
    End Property
End Class
#End Region
    ' This class is needed to ensure the folderbrowser is a STA thread, as a work around from running
    ' the jorunal in batch mode.
        Public Shared Function OpenFolderBrowser() As String
            newThread.Start()
            newThread.Join()
            newThread.Abort()
        End Function
        Private Shared Sub ThreadedFolderBrowser()
            End If
            folderBrowserDialog.Dispose()
            folderBrowserDialog = Nothing
        End Sub
    End Class
#End Region
        PathTextBox.Text = OpenFolderBrowserHelper.OpenFolderBrowser()
    End Sub
    '' <summary>
    '' </summary>
                Else
                End If
                LogDown()
            Next
            LogDown()
        End If
    End Sub
    End Sub
        End If
    End Sub
            Return False
        Else
            Return True
        End If
    End Function
    End Sub
            Try
                Next
            End Try
        End If
    End Sub
    Public Sub New()
    End Sub
        Try
            End If
        Finally
        End Try
    End Sub
        Me.SuspendLayout()
        'ExportButton
        'BrowseButton
        'FilterTextBox
        'PathTextBox
        'Label1
        'Label2
        'ErrorProvider1
        'ExportLog
        'BatchExport
        Me.PerformLayout()
    End Sub
#End Region
End Class
Thanks Petter, I'll have to give that a try.
thanks Petter,
I got some NXopen erors on some parts??
