GRiP write scratch file to OS
Is it possible to write a scratch file directly to the OS.
or do you have to send it to a info window and save that?
Cheers,
NXj
Cheers,
NXj
RE: GRiP write scratch file to OS
If you want results sent to the text file , you need to specify the output device, create the file and save it at the end.
If you want the program to write to the file, you need to use the WRITE command to the buffer that you opened the text file in.
Ben Loosli
