Flange Thickness Calculations
A pressure vessel has a 16" Nom. Sch 80 pipe attached (welded) to it , the length of pipe is 2 feet. At the end of pipe a slip on flange is to be welded and to be covered by a blind flange.
From where shall i calculate the desired thickness of flange, bolt size & bolt pitch circle dia. The vessel is of ASME Section III Class NB.
RE: Flange Thickness Calculations
Use a standard ASME B16.5 flange at the appropriate temperature/pressure rating.  Don't bother re-inventing the wheel.
Thanks for the advice.
Kindly tell me if it is a non standard flange and my vessel is NB. What should i do, Should i follow Appendix XI-3000 ?
Just to make sure I understand the situation:
You are designing a vessel to the nuclear code, but you don't know how to design a flange?
Yes, and the flanges are non standard , with one slip on and one blind to cover it.
safiamoiz,
          I think "jte" means that if you do not know how to design a flanged joint (SORF to Blind flange) then how the hell are you capable of designing a complete vessel to a nuclear Code. It seems like a very valid question!!!
It's the way of the world........
roca,
     Enlighten us.......
....you said it all DSB123
Can't really add much more can I
Amen.... DSB...... !!!
Sometimes a rant IS the correct answer to the question
Looks like the beginning of the end to me....
-MJC
