Steam Engineer License
I am a mechanical engineer for a fossil power plant. Many of the senior engineers and some managers with 25+ years of experience have their PE license and/or steam engineer license. The work that I do as a plant engineer does not really qualify as PE work. But what about the steam engineer license? As an engineer on the technical staff, I do not supervise operators and I am not I allowed to operate any equipment. In my case, am I still eligible to get a license or not? All of the information I see online seems to refer to operators or supervisors of operators. My job responsibility includes troubleshooting equipment, directing contractors, and managing projects, such as boiler or turbine outages.
RE: Steam Engineer License
I would go for your PE license. The Steam Engineer license is only a local license regulated by the Jurisdiction, and is for operation of the boiler only.
Obtaining a PE license is not all about design and analysis. Yes, that can be a large part of it, but there are lots of components of it that require the practical application of the principles of engineering, without a direct design or analysis need. Yes, you'll have to prove your capability at analysis or design in the testing, but that can be achieved without great difficulty.
It's a bit like the old story about the mechanical engineer who was called in to fix a boiler that no one else could fix. He took a small hammer out and tapped in a certain spot. The boiler then worked fine. His itemized invoice for services was $100...$1 for tapping, $99 for knowing where to tap. I've heard this story in different forms over the years. It's probably not true, but it does illustrate the point.
Engineering is a diverse and fascinating profession. Show that you are one. Get your PE.
Since you are practiced in ops and shutdown supervision, don't assume that you have suddenly become equally experienced in "pure" analysis or design calc's or pressure spec analysis just by having a PE registration. Combine the designers' years of experience in their specialties with your experience in field work, but don't try to replace their special knowledge with your own.
Add your more widespread knowledge to their detailed knowledge when you approach a problem. Use your widespread experience (as an plant operator you should also know piping, mechanical, electrical, project planning and budgeting - perhaps also welding, assembly, operations, testing, NDE, craft labor supervision, crane and safety and rigging, etc) to complement their more detailed intimate mechanical or pipe stress or welding knowledge.
The exam is straightforward, not especially easy but certainly not a nightmare. From teh statements, he has enough time working under PE's to get the signatures and references now - but not in a few years when those retire out and transfer elsewhere.
Sure, you don't need a PE to manage people, nor to run an outage or plan repairs and modifications. But it helps.
