Unit precision for table values
Hello, I did a search on this and didn't get clear results.  I'm looking to change the precision of values calculated using equations in a table, and am unable to find the 'Precision' list mentioned on the Table Equation Editor help page.  Seems that is not possible, from what I gathered in other threads.  Is this true?  Thanks!!
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: Unit precision for table values
You can use VBA function - Round(value;precision)
Thanks CorBlimeyLimey, that's what I needed!  I picked up on that from the ole RMB, too, but was not aware that the modifier needs to come first.  Cheers.
Mechanical Engineer
Field Forensics, Inc.
I am sorry, I thought precision in equations edit.
