Which Rubber Material is Best Suited?
Hey guys, I work almost exclusively with steel and a little with plastics, but now a product of mine needs a rubber part. The part will be used outdoors so it needs to be UV resistant and weather resistant. It also will need to be colored so it needs good color fastness. It needs to be fairly rigid and hold its shape, yet malleable under relatively small loads. It's function will be to hold bicylces (the frame is steel, this is just what the bikes sit on and get strapped too), so that could give you an idea of the ideal properties. Currently, we're using thermoplastic rubber, but the kind we have is nowhere near rigid enough and is succeptible to ripping and tearing. Any suggestions for other rubber types that may be suitable, and hopefully a little more rigid? It can be as rigid as necesarry as long as it wouldn't scratch the paint off of a bike frame.
Any suggestions would be appreciated, I'm new to working with rubber.
RE: Which Rubber Material is Best Suited?
Carbon black reinforced EPDM would be my first choice for this application based upon the requirements noted.
tom
