Alloy steel bar properties - Year 1962
Dear All,
I have liquid spring bracket detail drawing dated 1962. Bracket has 4 No. pins. Pins are made from "Alloy steel bar spec 3W.9C" or it can read BW.9C. I'm not 100% percent sure it's 'C' at the end as well. The drawing is very old and not clear unfortunately.
Could anybody help me to find out what properties of above mentioned alloy are or where to look for relevant information?
All responses will be greatly appreciated.
RE: Alloy steel bar properties - Year 1962
Any additional information about use and function might help.
A posted copy of the print would help.
thank you for your reply. I can not unfortunately post a drawing here.
The pin I'm itrested in is holding the spring, part of shock absorbing system.
if you look at this picture, you'll understand what i mean
it illustrates the idea
http://www.shockabsorbersworld.com/gifs/spring.jpg
bottom bar is my pin, it's holding shock absorbing system attached to the bracket, bracket is fixed to solid foundation.
Hope it helps and thanks a lot for your help
A good material to use would be an S-7 material which has very good impact resistance and very good wear resistance.
The reason for the print was during this peroid it was quite common to mention specific products by name instead of a generic steel call out.
I'm still looking for a specific reference for your material. The problem is that I've let most of my tool steel comparison charts get away.
So what is correct spec for the bar 3W.9C or BW.9C and what it all means? is W there for wolfram? Is .9C means 0.9% carbon content by weight?
