RSLinx+RSLogix+RSLogix Emulate500 and Vista
I have Vista as an operating system and have been trying to set up RSLogix and RSLinx. I can get as far as writing the ladder logic and verifying the program, but I am not able to go online and run the ladder program. I get an error:
(No response from processor at selected path/node!)
(InitDriver failed code -1)
(Current Driver AB_DF1)May not be running.
I have: (RSLinx Version V-2.54)
 (RSLogixEmu500 revision 6.00)
 (RSLogix Micro V-8.10)
RSLogix EMu has the selected nodes being found but does not communicate with anything else.
Is there a way to get it running with Vista? I have checked many places and cant find a guide anywhere.
I am grateful that I get the program to verify that it is correct but I would like for it to show the Counters work, Sequencers, ect.
I dont have a PLC, but I just want the ladder logic program to run on my PC.   Any advice?
RE: RSLinx+RSLogix+RSLogix Emulate500 and Vista
Try going online by going to Comms>>System Comms>>Who Active>> then select the emulated processor.
I gave it a shot.
The communications window freezes after that and does not respond to rslogix micro.
Error message:  (Diagnostic status failed: 0xFFFFFFFE)
What driver do you have configured in rslinx?
You should be using this driver.  Attached a screen shot
1. Open RSEmulate
2.  Use the FILE pull down menu and select OPEN
3.  Select the file you want to run in RSEmulate and press the OPEN button
4.  Assign the project a Station #.  A Debug File # if used can also be specified.
5.  Minimize RSEmulate and Open RSLinx.
6.  Go to Communication>Configure Drivers:
7.  Expand Available Driver Types drop down box and select SLC 500 (DH485) Emulator driver and hit ADD NEW
8.  Give the driver a name and press OK.  The default name (EMU500-1) is usual recommendation.
9.  Assign the Emulator driver a STATION NUMBER and STATION NAME:
10.  Minimize RSLinx
11. Open RSLogix 500
12. Go to Comms>System Comms
13.  Select the processor that you wish to communicate with. After selecting the driver you can choose the communications method you are trying to accomplish from the buttons on the right hand of the window: ONLINE, UPLOAD, DOWNLOAD:
There is not any screenshot in your attachment.  But 2.54 is ok and should have the dh485 emulator driver available to you
I tried the steps above but whatever the reason, RSLogix still comes up with. (Node 1 not found) and proceeds up the list. node 2, node 3, and so on....It still does not go online. Are there any other steps that I may need to do to go online?
@el124 = looking at your screen shoot, it seem that your RSLinx Classic Lite doesn't have (DH485) Emulator Driver.
(sorry! if my English is bad :D)
I know the emulator does not exist, that is why I am asking If I am using the right version?
el124
Are you running Vista?  If so see release notes here
Keep the following in mind when using RSLinx Classic v2.54.00 (CPR 9 Service Release 1) with Microsoft Windows Vista Business [32-bit] (Service Pack 1) or Microsoft Windows Vista Home Basic [32-bit] (Service Pack 1):
RSLinx Classic must start as an application; RSLinx Classic will not start as a service.
For RSLinx Classic to function as an OPC server, you must be logged on and RSLinx Classic must be running as an application.
The following communication drivers ARE supported and will be available on the Configure Drivers dialog:
1784-U2DHP for DH+
RS-232 DF1 devices
Ethernet devices
Ethernet I/P Driver
DF1 Polling Master Driver
1784-PCIC(S) for ControlNet devices
DF1 Slave Driver
DH485 UIC devices
Virtual Backplane (SoftLogix 58xx, USB)
DeviceNet Drivers (1770-KFD, 1771-SDN, and 1747-SDN)
SmartGuard USB Driver
Remote Devices via Linx Gateway
The following communication drivers ARE NOT supported:
1784-PCC for ControlNet devices
1747-PIC/AIC+ Driver
1784-PKTX(D)/PCMK for DH+/DH-485 devices
DeviceNet Drivers (1784-PCD/PCIDS)
PLC-5 (DH+) Emulator
SoftLogix5 driver
