Notched Steel Beam Seat Design
Hi Everyone,
I am looking for a notched wide flange beam seat at a steel girder design example. The beam seat depth must match the steel joist seat and a slotted steel plate is welded to the web to from the seat. Does anyone have a reference or example of this?
Thank you,
Steve
Thank you,
Steve
RE: Notched Steel Beam Seat Design
Sorry I can't picture your condition. Can you provide a sketch?
http://www.FerrellEngineering.com
If so connections like this have been discussed on here previously...you might try a search.
However, the design is rather straight forward. You'll need to check the shear capacity of the notched beam and any other limit state applicable, such as web crippling etc. found in Chapter J.10 of the AISC Specification. The seat plate may involve the calculation of the shear flow in order to design the seat plate-to-web weld.
For that, I know there was a posting about shear flow on this site that may have been the longest running posting of any forum in the history of the internet.
Imagine a Girder with a joist with a seat framing in from one side and a beam framing into the other (joist and beam 90º to the girder).
I think this is what the OP was talking about,...am I right?
I have notched and seated beams like this before when something was resting on top of the beam and a gap was not desirable.
I have also used many extended shear tab connections as you proposed.
My guess is, since the joist seat is "OK" making a seated connection out of a wideflange should easy to do.
I have also used "seat" angles welded to the web of a wideflange to accomplish this type of connection.
I have seen and used the detail you provided. Thanks for the additional info.
I have use the detail a few times when designing buildings that utilize OWSJ.
BA
