Neutral CAD file format with mass properties
Is there a file format that will allow you to export a Pro/ENGINEER assembly with the mass properties and open in the other main packages (ideally Solidwork, Inventor, Catia, NX and solidedge)
RE: Neutral CAD file format with mass properties
Yes export stp format as solid
