Routing - Changing The Default Min Bend Radius
I would like to specify a value for the minimum radius my spline can have, without having to go through the effort of defining a custom library. Is there not a way I can just select a spline and define the bend radius I would not like it to go under?
Thank You in Advance,
Nicole
Nicole
