Automotive Diffuser Questions
Assuming the rules allow for it is there any advantage in extending the diffuser beyond the rear bumper? My initial thought was "the bigger the better" but I am now thinking that is not the case. My second question is about the diffuser exit. Almost all diffusers for sale for street cars (that are likely mostly for looks) have a rounded exit like the first picture below. Race cars however all seem to have virtually no upward curve at the rear of the diffuser, F1 being the easiest to see but I know ALMS cars are the same way. Based on that alone I am inclined not to have any upward curve in the diffuser. Any help in my design would be greatly appreciated, I have the rest of the car well sorted but have little to no aerodynamic experience and much of the subject is counter intuitive.
Rounded:
F1:
Rounded:
F1:
RE: Automotive Diffuser Questions
TTFN
as for your 2nd point, if the afterbody is "holding the air down" then there'd be a significant net load, and a significant over-turning moment ... something i'd've thought was quite destablising ...
BTW is there an edit button somewhere I can't find?
(To edit red flag and ask management to make the change - try not to use it too much though.)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
A longer diffuser allows a more gentle diffuser angle for a given ratio of throat to exit area, so it will give less drag for a given downforce (see Hucho, of course).
The interaction between rear wings and diffuser geometry is exceedingly complex, in the absence of windtunnel or CFD then a DOE on a track may offer some insight, or some experiments with smoke, tufts and oil.
F1 diffusers are very much concerned with vortex control, they may not be a useful guide for a closed wheel car.
Cheers
Greg Locock
You really need to get a copy of Joe Katz, Race Car Aerodynamics. It answers all your questions plus a bunch more you should be asking.
You have the wing/diffuser relationship backwards. Ground effect systems, of which the diffuser is the final piece, are far more efficient than the typical automotive wing. So the question is, how can you maximize the wing's positive effect on the diffuser by increasing the "pumping" effect of the wing on the diffuser. i.e. the wing lowers the pressure at the diffusers' exit, increasing the volume of air moved thru it.
Short answer: keep the diffuser "roof" flat, don't exceed 7-10° or it will stall. Make it as long as you can w.o. stepping on it every time you raise the trunk lid. Install the wing behind the diffuser exit (I know you can't do that), or as far back as you can.
It's currently 7*
[quote]Make it as long as you can w.o. stepping on it every time you raise the trunk lid. Install the wing behind the diffuser exit (I know you can't do that), or as far back as you can.[quote]
This is really what I'm wondering about. The wing can realistically only be so far back. So is it worth making the diffuser end at the bumper to increase the pumping effect of the wing. Or will the diffuser be more effective with the extra length regardless of the reduced effect of the wing.
2. What ground clearance are you running at the diffuser leading edge? Closed wheel race cars typically run 1.0 to 2.0" at that point Assuming parallel walls on the diffuser(s) sides, the trailing edge height of the diffuser roof should be about 5 times the leading edge ht. in order to achieve the expansion ratio needed. If you're running 5" at the leading edge, you can see you've got a problem (a 25" trailing edge!)
3. The diffuser is only part of a ground effects system and is useless by itself. The flat floor in front of the diffuser and diffuser feeding is critical. If a flat floor in front of the diffuser can't be installed due to mufflers, differential, suspension components and the like, you may be looking at a mostly cosmetic exercisel Unlike open wheel cars, (and for reasons too complicated to explain here), closed wheel car floors/diffusers are primarily fed with flow coming in diagonally under the sides of the car. And yes, vortex generation due to the exact diffuser shape is crucial in making the whole thing work.
As for the flat bottom, I have the front splitter about 2" off the ground and about halfway back it gets down to about 1" off the ground before sloping back up around 7* all the way past the trunk.
Your comment about being fed from diagonal flow has me concerned though, I have just finished building side skirts that for all intensive purposes touch the ground. Should I not run these?
Mike Halloran
Pembroke Pines, FL, USA
http:/
My intention is not to generate lift on the front but to generate as much downforce as possible around the center of the car. Based on a lot of race cars I have looked at it seems the front is usually a bit higher. I could be wrong or there could be another reason for that though.
Mike Halloran
Perhaps you've duplicated the raised front floor inlet as seen on recent Le Mans cars. That was a rule introduced by the organizers to REDUCE downforce and improve safety at very high speeds. If you go from a 2" high floor at the front to a 1" high floor mid chassis, you will develop a positive pressure zone under the car. That's why everyone runs the front as low as practical and then runs approx. 1° rise the rest of the way back to the diffuser entry. That way there is a small neg press under much of the floor because the increasing ground clearance helps compensate for the floor's gradually thickening boundary layer.
Once your diffuser starts working, it will demand more volumetric flow than the tired flow coming from the front end can supply. That additional volume of flow will come in from the sides, and a good thing too. This side feed flow will have a thin, energetic boundary layer and because it is freshly attached, it will be able to cling to the diffuser roof as it turns the corner and heads up the hill. You can check this behavior by putting drops of thin tracer oil on the bottom of the floor and seeing where the air flow is carrying it.
Paul6
