What is the probable cause of steam moisture
We have experiencing steam moisture in the dehumidifier unit where we used steam to dry the desiccant wheel. The boiler we use to supply the operation is 100BHP. After we replace the reheat coil and defective steam trap, the problem is still re curring. May I know what is the cause of moisture in the steam and how to prevent it?
RE: What is the probable cause of steam moisture
Was the boiler recently renovated or reworked ?
Could there be some non-operating steam traps between you and the boiler
-MJC
