Paralleling of Wye-Connected & Delta-Connected Generators
Is it possible to operate generators in parallel which are connected in wye & delta? Assuming that all general requirements are met except that of their configurations..
thanks in advance
thanks in advance
RE: Paralleling of Wye-Connected & Delta-Connected Generators
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
How do you protect the delta-connected generator from ground faults? Since, it has no zero sequence current.
If your sets are above 1000 KVA you probably want some advice from the fellows who work with the large sets such as ScottyUK.
Bill
"Why not the best?"
Jimmy Carter
