ZYTEL 80/33 does it have a shelf life?
I purchased a plastics manufacturer and we had excess supply of Zytel 33% glass material that is 10 years old virgin in boxes.  Is the material still good???
RE: ZYTEL 80/33 does it have a shelf life?
If the seals are intact and there is no contamination, it should be mostly OK.
It will have absorbed some water from the atmosphere as I doubt it has been stored in a pack with extremely high barrier to moisture transmission.
If it is wet it will need to be dryed. This will be fairly difficult as the water will be well soaked into the granules.
If it is dried under vacuum, it can be done perfectly without damage, however very few moulders have vacuum dryers.
If done in air, it should be in a dehumidifier, but the time and temperature required will cause some oxidation.
This oxidation may cause some yellowing and a minor loss of properties.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
