Extract ALLCD history ouput using python script
Friends,
Can anyone help me with the extraction of ALLCD history output for the entire assembly at the end of time step ('Roll_Static' in my case) using python.
odb.steps['Roll_Static'].historyRegions['Assembly ASSEMBLY'].historyOutputs['ALLCD']
This is what I have so far and I am not sure of accessing the data from here on. Any suggestions or example script will be appreciated.
Niranjan
RE: Extract ALLCD history ouput using python script
Found the solution pals :)
required line in script:
odb.steps['Roll_Static'].historyRegions['Assembly ASSEMBLY'].historyOutputs['ALLCD'].data
Thought it might be helpful to others.
Thanks anyways,
Niranjan
