Section Line add arrow segment error - possible solution.
If you receive the message "Section Line add arrow segment error" go to "Preferences" /"Section Line" and check out the arrow sizes A,B,C they may be large unrealistic values. If so go for "default" or a realistic value to suit.
Hope this helps.
Hope this helps.
RE: Section Line add arrow segment error - possible solution.
I have had that error, but never found out why, thanks for posting
