Condensate Induced Hammer Pipe Damage?
Found this in a 50# condensate pipe run.  Any ideas on the damage mechanism? It's carbon steel pipe.
-Mike
RE: Condensate Induced Hammer Pipe Damage?
I assume it is pitting corrosin in the photo? if so CO2 is likely the corrodent. You will need to vent the non-condensibles or provide additional amine inhibitors.
Or is it blistering?  What does it look like lightly cleaned?
Plymouth Tube
Rounded pits with steep walls, I woulg agree looks like CO2 pitting, have water in your condensate accumulating/condensing here.
Try this one...
http://pipelinemaster.wordpress.com/
CO2 corrosion (carbolic acid is the classic mechanism in condensate piping systems.
But your picture looks more like an O2 corrosion mechanism
-MJC
Was just curious (for a little bit more info), what was the "clock" orieentation of this damage?
-Mike
