Rendering with transparent back ground
Is there any way during the render set up (Visual Studio) to put the back ground to transparent which will avoid the future selecting of the object while working with the generated image in Photo Shop, Illustrator, etc.
RE: Rendering with transparent back ground
Not sure this is possible. First you'd need to save to a format that supports alpha channel (transparency), so jpeg is out of the question. I don't remember which other formats a render can be saved to.
