Drawing Error: "Only a non-associative dimension...."
I have a catdrawing that was generated from a catproduct.
When I originally created the catdrawing I could dimension the geometry with no problems. I found I had missed several dimensions several days later. When I opened the catdrawing to add the dims I get the drawing error--
"Only a non-associative dimension can be created in this configuration. Current dimension creation options do not allow the creation of such a dimension."
Any ideas on this???
RE: Drawing Error: "Only a non-associative dimension...."
