What are causes of a bad High Pressure Switch?
I had a hvac tech come out due to no cooling.
He said i need to replace my high pressure switch and that the contactor was bad and needed to be replaced.
1) what are the purposes for each
2) what generally causes them to go bad?
thanks in advance.
thanks in advance.
RE: What are causes of a bad High Pressure Switch?
If not there, the pressure could get high enough to blow the rupture disk and vent the refrigerant charge. Then your low-pressure switch would trip the unit once all the refrigerant is gone.
Imok2 has the most common cause of failure, but the contacts can also go bad from repeated use.
Good on ya,
Goober Dave
They don't die often. I have 20 on the roof of this building, we've had to replace three over the past ten years.
Good on ya,
Goober Dave
I have experience with high pressure switches on boilers. The previous responses seem to be for other applications.
What is the application in this situation?
