8-to-256 decoder/demultiplexor possible?
um im building a computer interface and im using 1 of the contorl lines to turn the interface into "card select mode" wehre the 8 bits of the data select teh card, i want to be able to have 256 cards so i need a 8-256 demultiplexor to select the card based on the value of the data lines
Does this chip exist, if not how can i rig up a series of chips to do the same
Thanx in adave
RE: 8-to-256 decoder/demultiplexor possible?
e.g. 74ls138 ( 1 IC / 8 lines== 37 IC-s)
If need more, send FAX#
<nbucska@pcperipherals.com>
The 74LS138 is a 1-of-8 decoder/demultiplexer. This device is ideally suited for memory chip select address decoding. The multiple input enables allow parallel expansion to a 1-of-24 decoder using just three 138 devices or a 1-of-32 decoder using four 138 devices and one inverter.
Beyond that size it starts to get complicated!
You can do it with 17 4-to-16 demultiplexer ic's, with the first stage (one demultiplexer) you enable one of the other 16 -second stage-, using the 4 most significant bits of the input bus, and the 4 less significant bits driven to the inputs of the 16 second stage demultiplexers, you can use the 74154 ic to do that thing.
Use a shift register.  32 ic's, no spurious logic.  Build it up as you test it.  2, or 3 control lines.  If you need power, use Texas part TPIC6B595N (LED driver).
Might be easier to use a PAL.  One chip ...
Check Altera or Xilinx.
Dean.
Chancy99: A programmable chip with 264 I/O pins will be
too expensive -- not to speak about software cost and
learning time...
I used a PIC16C55/57 as an 8-bit comparator. 8-position DIP switch tied to port C
with appropriate pullup resistors, and the 8 address bits to port B. The software
compares the two, and when they are equal, it outputs a pulse from port A. I
have a STROBE bit tied to one pin on port A, so it only triggers when I want it to.
Otherwise, it could be decoding while bits are still flipping on the bus.
With this method, I am able to decode three different addresses per chip, so I can
have multiple, separate functions on the same card. I use the pulse from port A
to trigger a data latch, or a DAC with internal latching bus interface, or the enable
line on a 4-16 decoder.
