How to create dogleg dimension? (NX5)
Is there an easy way to create a dogleg or jogged extension line for a linear dimension?
RE: How to create dogleg dimension? (NX5)
Do you have the dimension down and simply want to add a jog to it?
What version of NX are you on?
Either adding it after the fact or when creating it, whichever works best.  I am using NX 5.0.4.1
To add it after the fact:
Inset > symbol > user defined symbol > on top switch to "utility directory > pick either "break15" or "break30" > in the four icons below pick the left one (add to drafting object) > pick the drafting object > pick exactly where on the object that you want it > cancel
Oh, i see, i am sorry
If there is a way to do it I would like to know.
What I have done in your situation is make sure the extention lines are dimensioned to the base of the groove and then change the angle of the dimension
dimension style > line arrow > "F" change to what looks best
I also tweak the "H" and "J" values so the gap is very small and it is very clear where the dimension is going to
I hope someone else has a better answer
I have never seen that kind of dimensioning technique supported by any standard that I'm aware of. Which may serve only to prove that I've better things to do than read the obscure minutae of drafing standards, so I could be wrong.
I have attached what is supported by NX, which is an offset dimension created by adjusting the F value of the Line Arrow Tab under the dimesion Style settings. Personally I think this is as good and possibly as clear as you'd ever need to be.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Thanks Hudson,  that will work.
I understand you can do dogleg dimensions using the 'ordinate' dimensions feature. (Insert > Dimension > Ordinate)
This may not, however, suit the 'house style'for your drawings.
I used to follow your approach with a previous employer but it does mean that the dimension doesn't stay associative to the feature. But aside from following appropriate drawing standards, the main thing is that it should be clear an unambiguous.
Hudsons approach is cool too ... I'll have to remember that one!
I agree, we are just looking for something clear and unambiguous.  We do not have strict drafting standards.
To maintain associativity, I have constructed doglegs that return to the original dimension location, then add a gap to the extension lines to meet the end of the dogleg.
It's a PITA (creating 6 curves), but it works and leaves a clean dimension.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
