Export ASM as workable format
Hi guys, I'm trying to export an ASM file into something useable (stl, obj), keeping all of the parts as seperate objects. I have managed to export the whole ASM as an STL but it's just a mess of vertices, and I can't select individual elements.
Could anyone give me a nudge in the right direction?
Many thanks.
Many thanks.
RE: Export ASM as workable format
When I try to export as a STEP it says : "This model contains no bodies. An output file will not be generated"
Which I don't quite understand as it exports as a solid in STL format.
To make it slightly clearer what exactly my purpose is, I want to be able to load the full asm assembly in 3ds Max, and be able to select individual elements...
Thanks again,
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
However, for complex items even parasolid sometimes falls down.
I had to save some parts of an assy individually a few weeks ago because when I did it as part of an assy they wouldn't come through into the other users CAD package.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Both these will give you similar problems in 3ds max and you will not be able to select individual parts. As you have seen already.
A great solution for transfering data between any MCAD system and 3ds max is PolyTrans from Okino
http://www.okino.com/conv/conv.htm
This will take the SE Assembly straight in and then allow you to save out a 3ds max file.
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
