catia v5 vba Properties editor
Hi I was playing  with vba and created a catvba to put properties and added properties on a catpart or product
It will also
-allows you to select from  screen or tree
-change all instance names inside a product at the same time
-allows you to take added properties  from selecting  another catpart or product
-remove formulas
-change added properties names or values (if not connected  to a formula)
-add or remove any  added properties
When you run this it will ask you to select only in the prompt  at the bottom.
If you like it or want to give any suggestions please give me some feedback
Thanks Charlie
