RSLogix 5000 CAMs
RSLogix 5000 CAMs
I have an application with multiple axis cam'd to one another and the transition points are pretty rough. This is a welding application that tracks an oval path, as it transitions from the long radius to the short radius the torches jerk violently which affects the weld quality. I have adjusted the speed changes in these area's but I have to believe there is a better solution to my problem. I am not well versed in this type of motion planning and would appreciate any and all advise.
RE: RSLogix 5000 CAMs
Second thing to check is that there is a smooth transaction between cam profiles. That your cam profiles smoothing transition from one profile to the next. You can use the pending cam feature to automatically execute the next profile when the current profile finishes.
Feel free to give me a call with any questions.
(215) 262-6793
www.HearnEng.com
