help in sheetmetal
help in sheetmetal
help in sheetmetal
Im using solidworks 2005 when i draw a sketch then base flange it gives you 2 direction options .
when i send them to a suface the pattern displays but wont flatten any reason for this
RE: help in sheetmetal
Can you post a screenshot or the actual file?
stanny123,
The upper left corner of your screenshot shows that the file is an assembly.  Are you trying to flatten in a part or assembly file?
- - -Updraft
hi updraft
no i cant open it in apart i get this message pops up
To flatten sheet metal the part must be a part, not an assembly.
- --Updraft
hi updraft i have done as a part,
wot i have done is drawn a sketch in the middle then direction 1 up to a surface, direction to 2 up to a surface.
the surfaces are planes, which are different plane to each other. if i do them separate halfs they will both flatten. but seems long way round when it would be nice if it did it one piece.
Why not extrude from one plane to the other, or Mirror the first half?
Can you post the part for review?
There are usually a variety of ways to do something in SWX and sheet metal is a good example.  My own preference is to model the part to make the shape I want and then at its end turn it into sheet metal.  (Pick a main face and Insert -> Bends.)  Perhaps if you were to try this technique you might have better luck.
- - -Updraft
I notice that the sketch is an in-context sketch. I wonder if that could be an issue.
Can you try using a Unfold feature and check if it works fine?
a sheet metal part must be the same thickness to flatten.
