Production resetting protective relaying
As the subject says, production resets the relays without any thought about a downstream fault. This is on 4.16 GE switchgear from the 50's. Faults are uncommon, but when there is one the relays are reset, and the breakers are closed several times before an electrician is called. We don't have 24hr coverage, but someone would be willing to come out and check the circuit before closing the breaker. We had a large motor go to ground and it tripped the feeder. This was in the middle of the night, and production reset the breaker and tried the motor 4 times before calling an electrician. We also had an animal find its way into a 4.16 fused disconnect, and again the breaker was closed several times before anyone was called. All three fuses opened eventually, and cooked the spring clips also. This is unacceptable in my opinion, and I hope to be able to change the standard procedure soon.
What is the common practice in large industrial plants? Surely this couldn't be commonplace. I would like to try to find some general safety guidelines concerning this matter.
RE: Production resetting protective relaying
Generally our operators follow this practice. But no-ones perfect.
On the other hand, relay targets should be reset before the breaker is closed back in. The targets should logged in the log book.
David Castor
www.cvoes.com
I once found control switchs with keyed handles, which I tried to use in breakers as the maintenance switch.
Be careful.
Depending on the politics, it maybe easer to justify fixing the problem of old relays.
I have to say I was surprised when reading your posts at the (lack of) procedures being used.
I've noticed since the economic collapse a lot of industries are cutting costs wherever possible to keep from being shut down or having the plant moved to another region. Your issue seems to have been an on going problem though.
Closing breakers into a fault puts serious stress on equipment. Doing this multiple times in a short time frame will shorten the life of your equipment as well. Maybe you can find some information to support this for your report to show the long term dangers/costs associated with poor procedures.
Don't put yourself in the middle of a political issue in case things get ugly. State the facts only. Try not to mention specific personnel who have been involved with these poor procedures.
Mark
Further, on motor protection, we commonly segregated some faults ((ground fault, instantaneous overcurrent, phase imbalance, motor differential) to operate an 86 device lockout relay, while motor overload could be reset for a restart. Operators were told specifically NOT to reset the 86 device because that was NEVER an indication that they'd overloaded the pump/compressor/whatever, i.e., process-related, rather 86 operation indicated potentially serious electrical faults which had to be investigated before a retry.
In training I presented on new equipment installations I represented this as the difference between a rebuild (expensive) versus a replacement (VERY expensive), plus I emphasized the dangers to personnel and equipment if they kept hitting a faulted cable or motor or transformer with voltage.
I'm not saying that these words were always heeded, but that's what we did.
old field guy
