taut flat cable parallel to roof to support a roof?
Pals
Will a set of cables, parallel to a simple roof, work just like purlins to support a flexible roof material?
For a cable to work I think I need a profile with a sag, so that no further sag can occur under load
But the architect says no sag.
Anyway around this. Seems impossible to me.
respects
ijr
respects
ijr
RE: taut flat cable parallel to roof to support a roof?
but you say "flexible roof" ... like a tent ?
Dik
You might also consider how you know what that initial tension is. Telling a construction worker to "tighten that nut until that cable is straight" could lead to highly variable results.
Temperature effects would also affect cable tension.
If he wants no sag, tell him to outlaw gravity. (Obvious God complex, so let him do it). You can't do that.
Structural Engineers are from Reality, Architects from Fantasia.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Michael.
Timing has a lot to do with the outcome of a rain dance.
yes, a tensile fabric will be hung on cables that act as simple purlins(same way you put purlins on an industrial one story building frame)
paddington, I am not after the equations really, I am after some experience on these issues. I appreciate your immediate response howeve and will appreciate more.
I found that article is inspiring. As usual JAE, you inspire. Can't thank enough
My application involves a cable flat in the sense that it is parallel to the ground with loads suspended on it, and even a small load brings about 10kips(5metric tons) tension and a huge sag.
It hints sensitivity to loading. No temperature analysis yet.
respects
The only possibility I can think of is somewhat awkward, it is to used a sagging cable, supporting at intervals, another almost straight cable or pipe, much like a suspension bridge. It is awkward because of the number of penetrations for the supports.
Other than that, I think the architect needs to ask the Great Architect of the Universe to change the laws of physics.
Michael.
BA
Paddington and BA are just being killjoys, they always want to bring equations and the laws of physics into the discussion. They don't know that your arch. is on a first name basis with the Great Architect of the Universe. I can just hear him/her saying "and there shalt be no G.. Damn sag in the cable." JAE's picture is a special case, quite clever, but I didn't see much article. They initially stretched the radial cables btwn. an exterior compression ring and the center tension ring structure and then tensioned them to some predetermined level. They pulled the tension ring down, thus prestressing and stretching the cables further, and installed the conc. planks which work in compression when the tension ring is released. Their trick is to calc. the prestress so that any anticipated live loads cause the tension ring to move, up and down, vertically within an acceptable range. This is not 'no deflection' due to added load, but you don't see the deflection in terms of significant added cable sag. This is easier to do in a circular form (tension and compression rings) than in a rectangular building form. Their system is attractive because the reacting force systems make up the roof, are shaped well to do this, and are internal to the roof system, and not an external tie off.
Let's see if I have the right picture: flat roof structure; beams spaced at X; cables (like purlins) spaced at Y, on top of the beams; flexible fabric stretched over the cables; none of these have any deflection or is it just sag in the cables which must be zero. You'll want to patent this because it will be a first. Your first gut feeling about cable sag was right on the money, except more vert. load will produce more sag and higher cable stresses; later you say the cables seem sensitive to loading, right again; and you say you haven't considered temperature effects yet. Don't forget to consider the rain filled swimming pools, each X long and Y wide, which will form on this roof system.
The arch. seems to have missed the 'gravity and loads thing' in school. You must explain this to him/her because you can't overcome it. Part of the architectural sex appeal of these tension structures is their deflected shape, and you can't ignore it. You must consider cable and fabric stretch, ponding, load accumulation, drainage of any low spots, etc.
Thanks for the detailed posts. I dont want to extend this more than worth your time.
But isnt it true that no amount of prestressing can make a cable flat. Since h=0 means infinite horizontal force, doesnt the contrary mean no sag-free cable is possible? A sag of a half inch(roughly 12mm) would reduce the force significantly
So here is what I am goint to do. I am goint to provide my X cables(X is parallel to roof slope) and then provide stiff Y purlins. This way the two will interact and I will have a safety margin, while pleasing the architect(Sorry I seem to have no real alternative).
respects
ijr
You may indeed be sorry if you take that option. Why is pleasing the architect your prime concern?
BA
You are right I will be sorry. But I have to ensure safety to the level of my knowledge, which simply says cable takes transverse load only if it can take a shape different from a straight line between the ends.
However this architect, a nice man too, insists and he is the one who calls all the shots.
think of calling the shots BA
respects
ijr
BA
E.g. a tubular truss, finished in flat black, with one chord finished bright.
E.g. a cable strung as a catenary, with queenposts holding up the structure, all finished in a way that hides them, and a highly visible, straight, decorative cable, strung where the architect, and the great unwashed, can see it.
Mike Halloran
Pembroke Pines, FL, USA
You can explain the principles once again while you wait for the tow truck.
Mike Halloran
It's not a matter of your (or our) respecting or disrespecting the arch. or of knowing he calls the shots. If he has enough money to throw at this roof, you can do almost anything. You can make it carry the roof load and make it safe, you must. But you are his consulting engineer, not just his calculating machine. And, given the fact that the arch. doesn't seem to understand the physical laws by which we must design and live, you must go on record with him about what he is asking for, and what you are doing to try to accommodate his wishes, and what the results will be in the way of forces, deflections, cable and fabric sag, etc. Since there is no such thing as laterally loaded cables and fabrics which do not have any sag or deflection. This should be in the form of a letter and report and calcs. which explains what the final results will be, with proof that he received the letter and understands the report. Then you may still be sorry because the argument with him continues; but at least you won't be sorry because you ended up in court facing him, because he doesn't understand you (and he by playing arch. and wishing hard enough) can't defy gravity and you can't do the impossible, just because HE says so. The whole thing may be just a matter of degree. Does he mean you can't have a cable sag equal to 1/3 of the cable length; and do you think he means you can't have a cable sag of 6" in 30'?
One of your biggest problems may be designing the cable restraint structural system in this rectilineal structure. My second paragraph, above, still stands, you have just rotated my system by 90° and now claim a sloped flat roof. You still have the potential of ponding (growing rain filled swimming pools) on the tension fabric skin.
And what about deflections of the cable supports?
From the posts here I have fully understood that all friends here agree that taut horizontal cables can in no way support gravity loads.
I am going to use good purlins and let cables stand there basically idle. so I wont have a load carrying or a frequency problem
respects
ijr
Dik
Just wanted to clarify that for a 100 lb on 1 in 100 slope the tension would be 5000 lb and not 10000 lb?
T = PL/4D or P = W/2 tan θ
We are Virginia Tech
Go HOKIES
Let the horizontal component be H. If the total load is W, the span is L, and the sag is D, then:
H=(W/2)(L/2)/D, and the Tension = the square root of the sum of the squares of H and (W/2). The tangent of the instantaneous slope at the support is (W/2)/H.
Once the tension is determined, the intermediate sags can be calculated.
As a check on a program result, I would put that on a spreadsheet to check tensions for various sags.
Michael.
P = W/2 tan θ
P = Tension in Cable
W = Point load in the middle
θ = slope
T = PL/4D
T = Tension in the cable
P = Point load in the middle
L = Total length of cable
D = Sag at location of point load
Go HOKIES
Michael.
