Embedded Plate Design
I was wondering if anyone here knows of software to design steel plates embedded in concrete with nelson studs or even some good literature? I'm looking for something that would use the Canadian codes but if not that's okay. Just seems like topics like these get left out of the codes as they require input from the steel codes and the concrete codes.
The only place I can seem to find any information is the CPCI (Canadian prestressed concrete institute) design manual and the design process is pretty long. The older code was much more general and simple. Any help on this topic would be very much appreciated as I seem to run into these plates fairly often with tilt up buildings and renovations and don't like using an older code.
Ivor
Ivor
RE: Embedded Plate Design
You could use proprietary software such as HILTI Profis or Simpson's software.
However, I would suggest you get a good grasp of different failure modes in shear and tension before using any programs.
https:
http://www.FerrellEngineering.com
