speed of the motor
speed of the motor
Is it possible to change the speed of the motor without using variable frequency drives (VFD)? If yes,how? Thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: speed of the motor
Separate topic. Quite a remarkable products at:
http://www.magnadrive.com/
The product that they call and "adjustable speed drive" takes the place of the coupling and allows variable (externally-controllable) slip between the motor and the load (pump, fan etc). Take a look at their video.
It is normal in a motor of 220Vac that must apply 150Vac or less depends it the motor and the resistant pair.
The reduction is with a autotransformer.
Excuse my English
