Bolt length
Bolt length
Bolt length
Acording to an API 650 for a plant, what bolt lentgh is accepted on flanged connections, how many threads outside the nuts?
RE: Bolt length
Typically 2 threads should be out side of the nut. Check out AWHEM's website. They have a spec for OAL of studs and nuts. Also API-6A provides OAL for FLG X FLG connections.
Petrotrim Services
RE: Bolt length
MJC, thank you for the correction, maybe I should had asked for API only. Thanks jbeck I will look at API-6A
RE: Bolt length
jb:
API 6A aplies to wellheads and christmas trees:
1.1 Purpose
This International Standard specifies requirements and gives recommendations for the performance, dimensional
and functional interchangeability, design, materials, testing, inspection, welding, marking, handling, storing,
shipment, purchasing, repair and remanufacture of wellhead and christmas tree equipment for use in the petroleum
and natural gas industries.
Also I checked AWHEMS website, my problem is usually to make my contractor to do things thta are not in the contract or the standards... but finally they are making the correction, thanks a lot
