Reduce Worm Gear friction in reverse direction
I'm designing a worm Gear, module=1 and ratio 30. The lead is driven by a DC motor, and the worm wheel is connected to the load.
Although the motor power is controlled to protect the gear, when the load hit on the hard limit, the worm gear are stuck, and the motor can not turn it back in the reverse direction.
In order to turn it back after hitting the hard limit, I increase the voltage of reverse direction(3 times higher than the voltage of hit-direction). By this, the problem is almost solved, 95% of the trials are succeed then.
To make the design more reliable, my question is:
Is there anything I can do about the worm gear to reduce the reverse friction of the worm gear when it hit (module, pitch, worm wheel, mesh, ...), so that it can be easier to turn back after it hit a hard limit ?
Thank you.
Thank you.
RE: Reduce Worm Gear friction in reverse direction
I.e., add limit switches somewhere that will slow the motor as it approaches the hard limit, and stop it before it ever reaches the hard limit.
Mike Halloran
Pembroke Pines, FL, USA
... which will _always_ jam a 30:1 worm set.
... unless you _seriously_ reduce the drive torque before reaching the stops.
--- which requires limit switches or position feedback, so you might as well stop the drive before reaching the hard stops.
Mike Halloran
