Command Line TcEng Query
I have created query in TcEng (2005) which returns lots of results (100'000's). I then need to get these results into a txt file, so am using the print table option......
Is there a command line utility I could use to run the query and export the results directly to a file on the OS?
Cheers,
NXj
Cheers,
NXj
RE: Command Line TcEng Query
cheers for clearing the mental block.
NXj
