This exceeds the maximum number of margins allowed
I'm doing drafting - ordinate dimensioning, with individual defined margins for each hole and after the seventh hole I got that message above. Are there really limitations in number of margins ???? Nx7.o1Mp1
thx in ad
thx in ad
RE: This exceeds the maximum number of margins allowed
Like Cowski asked, Why do you need a new margin for each hole? Give us an example.
Ben Loosli
The question is why there is a limitation?
turn the question, why should I create new margins?
maybe I can learn something.
regards
uwam2ie
Ben Loosli
The margin itself is like the origin for ordinate dimensioning so your question is causing some confusion over how and why you'd have more than two per view, (one in each axis). Or how many views you're dimensioning to within a single drawing.
The inference if the features you're dimensioning are holes is that something like a hole table might be a lot easier for you to manage.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Holetable is nice, but you can not select a centerline crossing as origin.
thx
