LRFD Analysis of Tension Drilled Shafts
I have an underground box subject to large uplift among other loads.
When I model and analyse this box with actual loads and a client accepted factor for buoyance, it is stable without acounting for shaft-soil interface friction. However for the LRFD case it becomes unstable. I need to analyse this so I can design it structurally for the LRFD case. Can shaft perimeter friction be made into an equivalent spring along the length of the shaft? I also believe that the maximum stress would occur closer to the top of the shaft in the case of a homogenous soil strata, so I know it is not as simple as it appears from a geotechnical perspective. We have struck out belled configuration for quality of construction reasons.
RE: LRFD Analysis of Tension Drilled Shafts
