Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...keep up the good work with this forum, I think this is the best one around. ...you actually try to help people learn for themselves. ...I commend you on providing a very good, open learning atmosphere, where usually egos are left behind..."
Geography
balutan (Electrical)
21 Apr 10 15:37
Copied from wiki about RS-232, "the standard requires the transmitter to use +12V and −12V, but requires the receiver to distinguish voltages as low as +3V and -3V. Some manufacturers therefore built transmitters that supplied +5V and -5V and labeled them as "RS-232 compatible."
At what voltage rail does the RS-232 on PC transmit (typically)?
MikeHalloran (Mechanical)
21 Apr 10 16:33
Actual IBM-PC used +/-12, but you can't rely on a generic PC to do that, because many, many of them didn't.
Also; the nature of your question suggests that you intend to steal some current from the RS-232 interface.  Get the idea out of your head; many of them will barely light a small LED, much less power receivers and logic in your box.
Mike Halloran
Pembroke Pines, FL, USA
itsmoked (Electrical)
21 Apr 10 16:55
It's all over the map as it depends on lots of things.
Keith Cress
MacGyverS2000 (Electrical)
21 Apr 10 16:56
Assume the PC meets minimum specs (+/-3V) and be done with it.  Thinking otherwise is just a guess and will come back to bite you in the rear when you least expect it.
Dan - Owner
http://www.Hi-TecDesigns.com
zzzjim (Electrical)
29 Apr 10 17:53
Plenty of newer PCs and laptops no longer have the voltage to run 5V logic from RAW Handshaking lines .
 10 years ago these sat at +/-  7 to 9 volts
RS-232 Tx-Rx  ICs even had 232 in their names .
 Assuming any better than +/- 3V will work
    .. when it feels like it !
  ( measure actual equipment to be used for clues )
ScottyUK (Electrical)
30 Apr 10 3:32
Just think about how many modern PCs don't even have an RS-232 port, let alone a full-spec port. You are designing for a rapidly shrinking market. Anyway you can get more power and better speed out of a USB interface, and most computers of today have at least one USB port.
benta (Electrical)
30 Apr 10 9:57
Scotty, I don't think you'll find ANY computer today without a USB port.
Benta.
IRstuff (Aerospace)
30 Apr 10 10:15
Only if you don't consider the iPad to be a computer...
TTFN
30 Apr 10 15:14
I don't... :-p
Dan - Owner
photoengineer (Civil/Environmental)
4 May 10 14:01
+/- 5 V
Cedar Bluff Engineering
http://cedarbluffengineering.webs.com
4 May 10 14:43
Tell that to Allen Bradley's 1747-PIC which drew its power from the port. Damned things were 'usually' ok on a full-spec serial port, and somewhere between temperamental and plain dead on most modern ports. Ironically IBM laptop ports were among the offenders for refusing to work with this device. neutral
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
