drawing breaks and views
SW2006
can the vertical (or horizontal) break width be varied so as to include the resultant view within it, as per example?
RE: drawing breaks and views
You may want to consider Breakout Section View
~ BT
I know it wasn't possible, but now is.  I think the capability came in in SW08 or SW09.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Sorry my reply was a bit cryptic, hit Enter too soon.  You can add multiple Breaks in a single drawing view.
I read your post too quickly, I don't think changing the size of the Break will give you the cross-section as in your example.  You'll probably have to do as BluTurtle suggested.
