measure diameter?
measure diameter?
measure diameter?
I work in NX6 inch files and often use the analysis-geometric properties to check rads along walls. When I do want to check hole or shaft diameters the analysis and measure distance list radial values only. I have been using measure distance in an ISO view to check these to date.
Best way to measure a diameter to .0001 precision in NX6?
I'm a new user, please be patient.
RE: measure diameter?
Try using Information -> Object then picking your circular curve/edge. The info window will list radius, diameter, arc length, center point, and other stuff.
Great, thanks.
