Misumi downloads
Misumi downloads
Hi, Using the SolidWorks file format to download Misumi component CAD files results in the message along the lines of 'filename or type invalid'. Any suggestions of which other file format to use? Thanks
RE: Misumi downloads
1. Try dragging the link into window
2. Check the version of SolidWorks on the web as it can be newer than yours
3. Try parasolid or step instead of SolidWorks native file.
2. The Misumi site doesn't show the version of SolidWorks it's using. I'm using 2010 SP2.1
3. Neither Parasolid nor STEP worked either.
Go to Tools > Macro > Run and browse to the downloaded macro.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
As Deepak suggested, run the macro and it will probably build the part.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
-handleman, CSWP (The new, easy test)
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
