Sprocket strengths?
Sprocket strengths?
Has anyone found information on roller chain sprocket strengths? I look in my browning book and it has a list of HP ratings per revolutions per min. However this information seems a little skewed. On a 60p chain it says at 50 RPMs i need a 45T sprocket to put 3 hp into it. Is that right? Anyone have a calcuation or some kind?
RE: Sprocket strengths?
Force (chain pull) = Torque / (pitch dia. /2)
If you look at the sprocket ratings you should see that the sprocket ratings are designed to keep the chain pull within the limits of allowable working load, if you want a smaller sprocket you may need to use stronger chain.
so thats my output load how does that correlate with my sprocket? your saying the sproket will never fail before the chain im suspecting?
