Bolt tables of ASME B16.47
Hello
I want to know the dimensions of the bolt holes, diameter of bolt circle, etc. for B16.47 (like it's shown in table 7 of B16.5, for class 150 pipe flanges) but I don't find it anywhere in the Standard. Would you know where I can find those values? I'm missing something in the standard?
RE: Bolt tables of ASME B16.47
Yep, you're missing something in the standard!
See Table 30 for Series A, Table 36 for Series B if you're working in mm (2006 ed). The dimension is not shown on the sketch, but its listed in the table under "Drilling."
If you're working in inches, see Table I-28 or I-34.
jt
WOW.. yes... I missed that!!! thank you very much for the clarification!!!
