WELDMENT CUTLIST ISSUE
I have been trying to modify the decimal precision in the weldment cut list length column. I have tried to fix the units on both the drawing and the assembly, and I have tried to save a new cutlist and load from that but I still can't modify the length column. anyone got a better idea on how to fix this issue?
I have attached a view of the cutlist so you all can see the issue in the length column.
Colton, CSWA
Solidworks 2009
PDM Enterprise 2009
Dell Precision T7400
RE: WELDMENT CUTLIST ISSUE
Change the units in the Part file.
I have changed the units in the part file and the assembly file and the drawing file and I still get the same outcome.
Colton, CSWA
Solidworks 2009
PDM Enterprise 2009
After changing the units, maybe you need to re-insert a new table?
even with a force rebuild it will not let me change anything. I think it is something to do with the cut list formating. I cant even click on a cell to change anything.
Colton, CSWA
Solidworks 2009
PDM Enterprise 2009
