Is JIS 10k a pressure rating or a flange dimension only?
Would anyone know if the JIS 10k spec is for flange dimensions only, or is also a pressure rating?
If it's a pressure rating, would you know the pressure?
Thanks!
Thanks!
RE: Is JIS 10k a pressure rating or a flange dimension only?
http://www.litonguk.com/edoc/en_flanges5.htm
Heather's focus: Alloy Valves Duplex Valves Super Duplex Valves Monel Valves Inconel Valves Titanium Valves & 6 Moly Valves
