X ray after stress relief in sphere
Hello, acording to ASME VIII section 1 and 2, after performing the Stress relief procedure, does it comand to do more X ray?
X ray after stress relief in sphereX ray after stress relief in sphere(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: X ray after stress relief in sphere
jt
Just depends on how critical the vessel is perceived to be. Or if it's fabricated of V-modified materials. Though I hear claims that the cracking issues of a few years ago have been resolved.
But... the OP's question was strictly Code requirements, not "good practice" or owner's specification related.
jt
My initial question was: If the code orders or not to RT after PWHT?
especially on heavy wall where RT is so expensive
For Section VIII, Div 1; NO!
You either read the PWHT charts to understand what time and temperature was applied to the pressure retaining item or you can use hardness testing to check if the weld and surrounding base metal heat affected zone have been tempered from PWHT.
You said some specifications call for NDE before and after, can mention wich ones please?
jt
This is no joke....after hydrotest
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Would that job you currently have be fabricated of a PWHT limited material - perhaps one for which the welding procedures are only qualified to three or four PWHT cycles?
That's typically where I'd expect pre-PWHT RT requirements. When you perform pre-PWHT RT, then it is not unreasonable to ask for post-PWHT NDE - whether thats RT, PT, MT, shear wave, etc. is up to the spec writer. As mentioned, if its in the spec, then the owner is willing to pay for the extra effort in order to receive a more reliable / maintainable vessel.
jt
Luis,
According to ASME Sec VIII,DIV-1,welds have to be radiographed,as a part of the design efficiency, e.g RT-1,RT-2.... and others. No code will specify at what point of fabrication NDE (such as RT) has to be done, if so that becomes too binding. Often clients spefication, which is more suited to service conditions, specify if RT shall be done before or after PWHT.
Usually from codes perspectives for steels which are not prone to serious cracking (e.g P1,P3,P4,P5A) RT shall be done on completion of fabrication, prior to PWHT. For steels which may develop cracking upon PWHT, through secondary hardening, such as P5B, P5C additional NDE (RT/UT or others) should be done following PWHT, to safeguard the components.
From ASME perspectives, for PI materials RT shall be done prior to PWHT. If there is any additional project requirement of RT after PWHT it is above the code requirements.
we are used to RT after PWHT as it is not all that uncommon.
But after Hydrotest?
we have had to WFMT after hydrotest before for the same Wet H2S.
jt
For other P group materials, ASME B31.3 does not specify whether before or after PWHT so either would be permissible.
In sour service (both vessels and piping) I have seen many end user specifications that require that examinations be performed both before and after PWHT or that the be performed after PWHT. Some require that these examinations shall be no sooner than 24 hrs after PWHT and some specify 48 hrs.
